Robonik - Readwell Touch
by Robonik
 Microplate Analyzer
Readwell Touch is an Automatic ELISA plate analyser with user friendly and sophisticated on board software. It is a stand alone system for all routine immunoassays, Biochemicals, hormones and drug levels. Its versatile and extensive software supports most of the calculations required for interpretation of results. It is economical, reliable and high precision machine
FORUMSView All (3)
-Sérgio
Wed Sep 03 2025
Defeito
Estou com defeito em um , falha de tensão
Translation:
I have a fault in one, voltage failure
-carlossreis_5934
Sat Apr 23 2022
NVRAM Type
which nvram is used in this equipment?Reply
2
-shanmugam
Tue Apr 25 2017
Serial port communication
How to read the data from ELISA Plate analyser via RS232 port ?Reply
  • Accommodates different Microplate geometries
  • Plate shaking facility with variable speed and duration
  • Ability to read plate within seconds
  • Digital light control with unique circuit for long lamp life
  • Matrix mode for Result printing
  • Multiple blank setting in cut off mode
  • Storage of calibration curves
  • Storage of Plate results
  • Bichromatic and Trichromatic Readings
  • Various Curve fit mode like : Linear, Point to Point will scales such as Log ABS / Conc, Logit ABS / Log Conc, ABS / Conc, Log ABS / Log Conc etc.
Height22 cm
Length 36 cm
Weight10 kg
Width36 cm
