Medical International Research - Spirotel
by Medical International Research
Touchscreen spirometer, Oximeter® 3D Pulse Oximeter, Triaxial Accelerometer, Diary of Symptoms. Spirotel® is an ideal tool for home care and telemedicine. Spirotel® has been already chosen for numerous clinical trials and is also designed for research organizations, or CROs (Contract Research Organization). The key lies in its extreme flexibility. In this sector, the instrument's excellent customizability is a great advantage, so it will come as no surprise that Spirotel® has been adopted by several companies as an OEM (Original Equipment Manufacturer) solution. Established over two decades ago, MIR's experience has led to Spirotel®, which ensures that CROs can offer pharmaceutical companies a truly turnkey package, where the quality of all clinical trial phases is guaranteed.
[list] [*] Touchscreen is easy to use [*] Triaxial Accelerometer with movement analysis. Embedded step counter to measure physical activity, values such as the distance traveled during a test, VMUs (Vector Magnitude Units), and body position during sleep can all be estimated [*] Electronic Diary of symptoms for monitoring home therapy. This helps the patient fill out default or custom questionaires and reports, which can be used to assess his/her health and to communicate with healthcare professionals [*] "Traffic Light" system, questionnaire, and reminders to help the patient [*] Flexibility: Integration with numerous protocols. Customized software and hardware [*] Extended Memory: Stores up to 10,000 spirometric curves [*] Small Size: Usable in any situation and easy to transport [*] Rechargeable Battery: Durability and usability inspires confidence [*] Connectivity: Analytical results can be sent via the USB cable to any PC, even when the patient is traveling. A software application then extracts the data and sends it to the server [/list]
| Height | 92 mm |
| Length | 38 mm |
| Weight | 124 g |
| Width | 88 mm |
Flow Range: R16 L/s Flow Accuracy: R5% o 200 mL/s
