Detecto - 2381
by Detecto
Detecto 2381 Physician Scale
Detecto 2381 Physician Scale is eye level and weight measurements can be easily read from either side of the scale with its dual die-cast weigh beam. This model features a mechanical height rod and wheels for easy transport of the scale. The construction of the 2381 is sturdy steel, and the weigh beam is made of aluminum.
The 2381 uses metric units for both weight and height measurements, and its capacities for both are 180 kg x 100 g and 76 - 200 cm, respectively. The long-lasting electrostatic powder-paint finish will last throughout daily wear and weighing.
  • Height rod.
  • Wheels on bottom of scale for easy transport.
  • Dual-sided, die-cast weigh beam.
  • Electrostatic powder-paint finish.
  • Sturdy steel construction.
  • Made in USA.
Height76 to 200 cm
Capacity180 kg x 100 g
KindStanding
Width6 in
