Medela - Dominant Flex
by Medela
Features one-touch adaptable flow rates allowing for a wider variety of procedures to be carried out with just one pump. It is designed for use in hospitals, clinics, medical practices, and can also be used to provide the vacuum required for use with cardiac tissue stabilizers used in off-pump coronary artery bypass and for use with epicardial ablation probes.
[list] [*] Rapid vacuum build-up. [*] Quiet drive system. [*] Precise vacuum setting. [*] Protection against electric shock Class I. [*] Most popular format is the mobile model. [*] Swiss engineering and manufacturing processes make the Flex a reliable and long-lasting piece of technology. [*] CleanTouch technology of the on/off and flow change buttons reduces the risk of contamination. [*] High-quality housing materials can withstand potent disinfection agents, and the smooth, single-piece hood facilitates cleaning. [/list]
| Height | 8.2 in (pump) |
| Length | 14.7 in (pump) |
| Weight | 20.5 lbs (pump) |
| Width | 12 in (pump) |
Trolley Dimensions: 26.4" H x 19.3" H x 8.7" D Trolley Weight: 20.7 lbs
