HK Surgical - Aspirator Pump
by HK Surgical
Aspirator Pump
The HK Surgical Aspirator offers superior high-speed powered suction performance. It can accommodate up to four Baxter Canisters or two Abbott™ / Sorenson™ Canisters, eliminating time-consuming canister changes. The HK Surgical Aspirator is designed for powerful performance with minimal noise.
SERVICE COMPANIESView All Aspirator Companies
[list]    [*] AC powered    [*] Ideal for suction due to higher tort    [*] Maintains higher vacuum    [*] Piston/reciprocating pump    [*] Portable/compact/proven reliability    [*] Minimal control panel    [*] Infiltration pump can be placed on top of aspirator    [*] Pressure gauge built into pump, therefore it cannot be broken off    [*] Very low noise level allowing for sight and sound aspiration management    [*] 1/3 HP    [/list]
Height19 in
Length 13.5 in
Weight50 lbs
Width16 in
