Spacelabs - 90387
Spacelabs 90387 Ultraview 1700The Spacelabs 90387 Ultraview 1700 monitor combines the module-mounting capability of the 90491 module housing, with the processing and display capabilities of the 90385 UCW. The right side of the chassis is used to house the CPU and I/O PCBAs, while the left side provides two slots for module plug-in. The Ultraview 1700 is capable of driving an external speaker (either amplified or unamplified) or may stand alone, using the internal speaker. The result is a product that provides the same Ultraview Care Network™ capabilities as the UCW, but adds plug-in support for two modules in a single, compact unit, with a separate display. The Ultraview 1700 is primarily intended to function as a compact, two-module bedside or central monitor.
