Detecto - 448
Physician ScaleDetecto's model 448 features a height rod in inches and centimeters, wheels in back for easy transport, and a handpost, which is an important aid for the elderly or weak individuals. The platform cover is easily removed for cleaning. The die-cast beam can be easily read from either side. Now available in 500 lb / 220 kg capacities by using the optional counterweights.
[list] [*] Accuracy [*] Heavy-duty understructure [*] Die-cast beam, aluminum on black insert, easily read from either side [*] Mechanical height rod [*] Hand post for patient stability [*] Wheels for easy transport [/list]
Capacity | 400 lbs x 4 oz |
Kind | Standing |
