Skytron - UltraSlide 3600B
The UltraSlide 3600B represents the visionary benchmark in Top Slide surgical table design, including even greater imaging and versatility.The UltraSlide 3600B represents the visionary benchmark in Top Slide surgical table design, including even greater imaging versatility, lift and articulation power. Expanded features provide optimal patient positioning and C-arm access with 23” Top Slide, 1,000 lb. lift, 800 lb. articulation and full table functions. Additional features include removable back and leg sections, Auto Beach Chair position, 30° tilt,Trendelenburg and reverse Trendelenburg, and more! Optional Infrared (IR) Wireless Table Control is also available.
FORUMSView All (7)
1Reply3 years ago | Pendant Control Does anyone know a reputable company that repairs the Pendant control on these OR tables, or a possible second source to purchase a replacement?Reply |
2Replies4 years ago | cleaning manual cleaning manual availabilityReply |
1Reply5 years ago | Flex feature does not work The flex feature does not work. Is there a position switch for this feature?Reply |
[list] [*] General Purpose Specialty Surgical Table [*] 1000 pound lift [*] 800 pound articulate capacity [*] 24 inch minimum table height [*] 23 inch top slide travel [*] 57 inch imaging window capacity [*] Return-to-level [*] Auto Beach Chair Position [*] Removable back and leg sections [*] Full body imaging without special accessories [*] Durable one-touch pendant control [*] Battery power [/list]
Height | 24 in to 42.5 |
Length | 82 in with head rest |
Weight | 800 lbs |
Tredelenburg | 30 degrees |
Lateral Tilt | 30 degrees |
Patient Weight Capacity | 1000 lbs |
Width | 19.5 in |
[list] [*] 9-1/2” Slide-to-Head for Full Upper Body Imaging [*] 13-1/2” Slide-to-Foot for Full Lower Body Imaging [*] Full Body Imaging is achieved without having to orient the table (or patient)or add costly accessories. [*] A Full 23” of Top Slide permits both Upper and Lower Body Imaging. [*] Up to a 57” Imaging Window for Lower Body Procedures. [/list]
