Edan - F2
Has an extensive set of monitoring parametersThe F2 Fetal Monitor is capable of dual fetal heart rate monitoring, as well as TOCO, DECG, IUP, and fetal movement. Its extensive set of monitoring parameters and its lightweight, portable design make it perfect for obstetrical departments in both clinics and hospitals and for outpatient service.
- Easy to Read and Operate
- Simple workflow with silicone buttons for operations
- Advanced FHR Detection Technology
- Signals overlap verification to differentiate between twins FHR
- Signal quality indicator helps to optimize the probe position
- 12 hours of built-up memory for seamless monitoring
Height | 350 mm |
Length | 104 mm |
Weight | 3.5 kg |
Width | 300 mm |
