STERIS - AMSCO 3085 SP
by STERIS
You can safely raise and lower larger patients in both normal and reverse orientation and have virtually the same positioning capabilities as with other patients. The Amsco 3085 SP Table offers the same quality, reliability, and flexibility you-ve come to expect in all of our surgical equipment products.
1ReplyInvalid Date | Troubleshooting Steris table doesn’t move. Power supply and control board has been change. Any suggestions regarding to what will be the next steps? There is battery and ac power but no acceleration. Hand control flashes unlock button. no acceleration when you move the table manually or with the hand controller. Equipment: STERIS - AMSCO 3085 SP Reply |
5RepliesInvalid Date | Not showing power from wall, checked fuses I have a table plugged into a hot socket and has good batteries. The hand held remote is not showing power is getting to the table. I have checked the power on the cord and fuses . Is there a reste or could my charging unit be bad. Equipment: Amsco 3085 sp Reply |
0RepliesInvalid Date | Battery light on remote flashing Units remote battery light is flashing after over 48 hours of charge time. Unit will not work. Equipment: STERIS - AMSCO 3085 SP Reply |
| Height | 45 in max |
| Length | 76 in |
| Tredelenburg | 25 degrees |
| Lateral Tilt | 18 degrees |
| Patient Weight Capacity | 1000 lbs |
| Width | 20 in |
