Nicolet - Endeavor CR
by Nicolet
IOM Machine
The latest technology in intraoperative monitoring is the compact and rugged Nicolet Endeavor CR - the perfect solution for the mobile monitoring service or the space-conscious hospital.        The Nicolet Endeavor CR IOM Machine was designed to meet the physical requirements of a portable IOM Machine with robust multi-modality capabilities, while maintaining the highest standards of signal quality, in the harshest operating room environment.
FORUMSView All (3)
-aliamini
Sun Jun 29 2025
order registration
I need this device (used or ref) . please give me the price
Equipment: Nicolet Endeavor CR IOM Machine
-Kami Sey
Thu Sep 12 2024
need to buy , look for seller
Hi everyone , i need to buy a second hand of Nicolet Endeavor CR 32 or Xltek Protektor 32 IOM , does anyone have lead to trustable seller ?
-Hir
Sun Jan 17 2021
Amplifier
Auto test show me 200-5 amplifier erorr How can i solve this erorr? ThanksReply
[list]    [*] Amplifier settings for differential or referential allowing for 44 possible inputs    [*] Four high-level stimulator controls for protocol management    [*] One low-level stimulator control for direct nerve stimulation    [*] Automute reacts to ESU for automatic control of EMG audio output    [*] Display settings for all possible recording parameters    [*] Light mobile OR instrument at 27 pounds    [*] 16 channel amplifier has the highest sampling rates available, allowing for unprecedented data quality    [*] Panel grouping allows you to change your entire monitoring with a single click of the mouse    [*] FFT analysis allows you to set custom filters for any extraneous noise you may encounter    [*] Ability to run six independent stimulators simultaneously gives you the freedom you need in the OR suite    [/list]
