Ethicon - G110 Harmonic Scalpel
by Ethicon
Ethicon offers the most complete portfolio of intelligent energy solutions for open and laparoscopic procedures.
The Ethicon G110 utilizes ultrasonic energy to enable hemostatic cutting and/or coagulation of tissue. The system includes an Ultrasonic Generator, a foot switch, and a hand piece and is indicated for incising tissue when bleeding control and minimal thermal injury are desired. The system also offers greater precision in tight spaces near vital structures.
-jao1982
Fri Nov 19 2021
service manual
i´m looking for this service manual, pleaseReply
[list]    [*] Frequency: 55.5 kHz (output)    [*] Power Requirement: 115 VAC, 60 Hz, 2 Amps, 230 Watts max    [*] Fusing: Two, 3 AG Slow Blow 1⁄4” x 1 1⁄4”, 2 Amps, located in the power entry module. [*] Three, internal, 5 mm x 20 mm Slow Blow, 1@ 1 Amp, 1 @ 0.25 Amps, and 1 @ 1.6 Amps    [*] Air Pressure: 6 psi Max    [*] Air Flow: Approximately 20 liters per minute    [*] Ventilation: At least 2” in rear of the unit and the bottom vents should not be obstructed    [/list]
Height8 in
Length 12 in
Width14 in
