GE Healthcare - Marquette T2000
by GE Healthcare
Treadmill
The GE T2000 Treadmill is compatible with all GE stress test monitors and more. The extra-long, 60-inch treadmill surface provides an extra margin of safety for patients. The Series 2000 may be slowed gradually to a stop or stopped immediately with an emergency stop button. It accelerates slowly from a standstill to accommodate severely debilitated patients. Digital microprocessor control assures settings that never need to be calibrated. Its extremely smooth and quiet operation facilitates accurate blood pressure measurements even at high work loads.
FORUMSView All (3)
-Gerardskydive
3 years ago
Control problem
hello, I bought a marquette treadmil series 2000, but I have no control software, I am electronica technical, think of to put manual command, someone already put to work with manual contolo, I appreciate any comments.Reply
-LeCay
5 years ago
Upgrading its X86 CPU motherboard to a newer model
How to upgrade GE Marquette T2000 X86 CPU motherboard to a newer model of CPU motherboard?Reply
-StanG
5 years ago
I have a Com error code 100
Fellow techs, I have a customer with a G.E. Marquette T 2000 stress test unit with treadmill. They are having a COM ERROR 100. Can someone tell me what can be done to repair the issue, and exactly what that error code means? Thank you all!Reply
  • 60-inch walking surface
  • Two stopping modes
  • Standard full handrail set
  • Standard emergency stop switch
  • 0 to 25 percent grade range
  • Enhanced tolerance to electrical changes for greater patient safety
  • 3.0 horsepower motor
  • Self-calibrating for speed and grade
  • Digital control insures precise speed and grade control
Weight181.4 kg
  • Weigh Capacity: 450 lbs.
  • Speed Range: 0 to 13.5 mph
