Buffalo Filter - LapEvac®
by Buffalo Filter
Smoke Evacuation System
LapEvac, designed for use during laparoscopic surgery, will help reduce many of the risks associated with poor vision and loss of distension due to smoke & efforts to clear smoke and aerosols from the patient's cavity. This system is the world's first disposable, battery powered smoke evacuator that creates a constant closed loop flow to filter and re-circulate gas within the peritoneal cavity. LapEvac uses 99.999% efficient ULPA filter media with activated carbon to remove smoke plume and aerosols. This small, sterile unit connects to two trocars and quietly runs throughout the surgical procedure. LapEvac keeps the surgeon's view clear from smoke, minimizes the amount of CO2 gas needed to keep the patient's cavity distended, and also helps reduce the amount of plume byproducts remaining in the patient's cavity.
FORUMSView All (3)
-Duff Burkes
Wed Jul 24 2019
manual
service and op manual manual needed Reply
-samuel van
Wed Aug 02 2017
CD4 count
i am having a problem with error code 28Reply
-Arby
Thu Sep 24 2015
LapEvac Product Documentation
I am looking for user operation documentation (manual or instruction sheet) for the Buffalo Filter LapEvac. surgical smoke evacuator.
  PHOTO_2
  • Provides improved visibility
  • Creates a constant closed loop to filter smoke
  • Re-circulates gas into the peritoneal cavity
  • 99.999% efficient ULPA media @ 0.1 micron
  • Helps to maintain distension
  • Small, battery operated unit
  • Sterile & disposable
  • Noise Levels <47 dBA nominal
  • Housing Dimensions* (L x W x H) 4in x 4in x 6in 7cm x 7cm x 11cm *also includes 24" of sterile tubing at each end
  • Flow Rates with standard tubing sizes .14 CFM (4 LPM)
  • Electrical Environments LapEvac is battery operated.
  • Static Suction 3.2" H20 (mbar): 3.2"" (5.9mm Hg)
  • Static Pressure 0.85" H20 (mbar): 3.2"" (1.5mm Hg)
  • Weight 13.4 ounces (380 g)
  • Certifications CE Patent No: 6,544,210 and PCT/US2008/002759
