Pronk Technologies - FlowTrax FT-2
Infusion Pump Analyzer
The next-generation FlowTrax® IV Pump Analyzer provides the fastest tests results of any analyzer with a market-best measurement sensitivity of 0.8 microliters. Test results are achieved in a remarkable 3 minutes or less within a 1% accuracy for any flow rate from 1 to 999ml /hr. The Quick Prime feature rapidly readies it for use with no re-priming required between tests. A field-serviceable fluid chamber the only one of its kind on the market eliminates expensive downtime and repair costs. FlowTrax is compatible with any type of infusion device, syringe pumps, PCA pumps, ambulatory pumps, feeding pumps and more. FlowTrax FT-2 conveniently integrates the functions of three additional devices: (A) full-featured pressure meter with Electronic Occlusion test capabilities that can be utilized for testing any type of medical device for pressure or vacuum, (B) temperature meter compatible with any type of YSI 400 temperature probe for testing fluid, gas or air and (C) digital timer/stop watch that automatically starts and stops with fluid measurements. Eliminate the time and cost to purchase and calibrate four devices with a single ultra-compact, durable device! All features are NIST traceable. Unique Fluid Detection System. FlowTraxs patent-pending dynamic fluid detection system tracks fluid movement in real time with 1200 measurement points in a 1ml fluid column. This yields superior accuracy in fluid volume and rate calculations over any other analyzer.
0Replies5 years ago | BMET Pack PRO for On-the-Go Biomeds Pronk Technologies introduces BMET Pack PRO: a compact and versatile package that makes it easier than ever to travel with your test equipment between hospitals and clinics. Reply |
VIDEOS
- Unsurpassed Rate and Volume Accuracy
- Results within 1% accuracy for rates from 1 ml/hr to 999 ml/hr in less than 3 minutes
- NEW Electronic Occlusion feature
- Test any type of infusion device from PCA, syringe, volumetric to feeding pumps
- Unrivaled speed requires as little as little as 0.5 ml volume for low rate tests to achieve 1% accuracy up to 40X faster than other products
- Never miss a test result with Trend feature
- Capture real-time results to any File, Form or Record on your PC with DataSnap
- Market-best measurement resolution of 0.0008 milliliters
- Full-Featured Pressure and Vacuum Meter
- 0.5% Accuracy of Reading
- Utilize as standalone pressure meter. Test any type of medical device for pressure or vacuum (-12.5 to +75 PSI).
- NEW Electronic Occlusion Feature (0-40 PSI) with graphical chart and total elapsed time of test
- Measure real time and peak pressure
- 9 units of measure: mmHg, PSI (gauge), inH2O, cmH2O, kPa, atm, inHg, BAR (absolute and gauge)
Height | 5.5 in |
Length | 2 in |
Analyzer/Simulator Type | Infusion Device |
Width | 3.25 in |
