Masimo - Rad-57
by Masimo
A versatile handheld oximeter, featuring fully upgradable rainbow technology.
The Masimo Rad-57 Pulse CO-Oximeter (#9216) is a versatile handheld oximeter featuring Masimo SET Measure-through Motion and Low Perfusion Pulse Oximetry. It comes standard with Oxygen Saturation (SpO2), Pulse Rate (PR), and Perfusion Index (PI) parameters, but can also be upgraded to include rainbow SET technology.
-Pamela Williams
Tue Jun 02 2026
Service manual
I trying to find information regarding the PM schedule for this unit
Equipment: Masimo - Rad-57
-animalcrackers
Tue Feb 25 2020
keypad
How to installReply
SERVICE COMPANIESView All Pulse Oximeter Companies
[list]              [*] Continuous monitoring.                    [*] Portable.                    [*] Quick and easy to use.                    [*] Low Signal I.Q. (SIQ) Indicator: Identifies conditions of low measurement confidence.       Parameters: Measurement parameters can be added on after purchase, and come in the form of a software upgrade:                    [*] Pleth Variability Index (PVI): Helps assess fluid responsiveness in mechanically ventilated patients, aiding fluid management.                    [*] Total Hemoglobin (SpHb): Helps with quick, spot-check assessment.                    [*] Methemoglobin (SpMet): Helps identify methemoglobinemia, a dangerous and deadly reaction caused by many drugs routinely administered in clinical settings.                    [*] Carboxyhemoglobin (SpCO): Helps detects carbon monoxide (CO) poisoning.                    [*] Oxygen Content (SpOC): By calculating hemoglobin and oxygen saturation, SpOC provides a more complete picture of your patients' oxygenation status.                    Sensor and Cable Options: The Rad-57 can be used with the following:                    [*] Rainbow sensors and cables (such as the rainbow RC Cable, rainbow DCI Adult Sensor, and rainbow DCI-P Pediatric Sensor).                    [*] Rainbow sensors must be used when measuring Total Hemoglobin (SpHb), Carboxyhemoglobin (SpCO), Methemoglobin (SpMet), and Total Arterial Oxygen Content (SpOC).                    [*] Red reusable sensors.                    [*] RD, LNCS, and M-LNCS adhesive sensors.              [/list]
Height6.2 in
Length 1.4
Weight0.8 lbs
Memory72 hr
Width3 in
Oxygen Saturation Accuracy Range: 70 - 100% ul>              Pulse Rate Accuracy Range: 25 - 240 bpm              Total Hemoglobin Accuracy Range: 8 - 17 g/dL              Carboxyhemoglobin Accuracy Range: 1 - 40% ul>
