Huntleigh - Dopplex Ability
Automatic ABI system with people in mind.The Dopplex Ability automatic ABI system, Ankle Brachial Index has never been simpler or quicker. ABIs are calculated easily and accurately in 3 minutes without the need to rest the patient. Results are automatically calculated, classified and displayed with pulse volume waveforms on the LCD panel. The test results can be printed on either thermal paper or adhesive backed label paper via the integral printe
2Replies3 years ago | Ankle Cuff Inflation Problem Refer To User Manual Can you please advise - I completed a Doppler assessment yesterday and instead of ABPI results, the above message was displayed.Reply |
1Reply4 years ago | Huntleigh DA 100 BP Automatic ABI Turning off I have a customer who's Huntleigh DA 100 BP Automatic ABI is Turning itself off after 30 seconds to 1 minute of usage. A previous service provider has apparently replaced the battery but this has not fixed the problem. Could this be due to a Non OEM battery pack (Im unsure if Huntleigh chip or otherwise battery packs) or simply due to the battery needing to be conditioned ? Thank you in advance & I look forward to your input . Cheers Phill Reply |
SERVICE COMPANIESView All Blood Pressure Monitor Companies
[list] [*] Integral easy grip handle. [*] Integrated thermal printer (can be used with paper or label rolls). [*] Clear display showing test status, numerical results, waveform, and interpretation. [*] Simple user interface. [*] Color coded, easy connect tubing. [*] NiMH Battery: Integral. [*] USB Connector: Min [/list]
Height | 6.25 in |
Length | 9.5 in |
Width | 10.25 in |
