GE HealthCare - Ohmeda 4400
Infant Warmer
The GE Ohmeda 4400 Infant Warmer System uses a manual mode of operation that allows selection of the level of radiant heat output as indicated by the % power display on the control panel and the control circuit then maintains the selected level of radiant heat. Servo mode of operation allows selection of the patients control temperature and a control system modulates the radiant heat to maintain the patient at the selected control temperature. Alarms activate to alert the operator of a low or high patient temperature, a skin temperature probe failure, a power failure, equipment failure or a check patient prompt
FORUMSView All (3)
0Replies5 years ago | Where to buy Does anyone know if the old Ohmeda Airway Manometers with Over Pressure Relief and Dovetail Brackets can still be purchased? They were commonly used on the Ohmeda Radiant Warmers.Reply |
3Replies6 years ago | heating not holding a constant tempReply |
1Reply6 years ago | bed tilt function Access to tiltReply |
SERVICE COMPANIESView All Infant Incubators & Warmers Companies
[list] [*] Microprocessor Control [*] 20 Segment Output Control [*] Digital Apgar Timer [*] Powered Elevating Base [*] Pre-Heat Mode [*] Dovetail Rail Mounting System [*] Large bed accommodates larger infants easily [*] Bed height adjusts to comfortable working level [*] Advanced microprocessor system continuously monitor patient and machine status [*] Easy patient access from any location around unit [*] Heater Power: 550 Watts ±5% at maximum % power setting [*] Examination light Luminance: 100 (nominal) foot candles at center of mattress [/list]
Height | 80 in |
Length | 45 in |
Weight | 200 lbs |
Width | 30 in |
