Terumo - Terufusion TE-LM700
Standard volumetric infusion pump, peristaltic type.The simple way to get safe, high-precision infusion management.
FORUMSView All (3)
1Reply4 years ago | Service manuel LM700 Hello, does anyone have the service manual or the calibration procedure for a Terumo pump TE-LM700? Best regardsReply |
1Reply4 years ago | Service Manual for this equipmen Hi everybody! Does anyone have maintenance or sevice manual for the TERUMO TE-SS700/800? Need how to disassemble it. Best regards. Reply |
4Replies7 years ago | Service manual or part number Hello. I have some problems with this tipy of device . All the time show error buble detection in line, but line is full . After opening the divice i find the problem , its o smal plate behind the buble detection sensor.Can some one help me with number of smd pieces ?Reply |
[list] [*] Distinct easy-to-read display - can be read clearly from some distance away [*] Full-color visual guidance for less experienced operators - follow it step by step to properly install and set up the pump [*] Anti-free flow (AFF) function [*] Only seven buttons and a jog dial [*] Sturdy construction [/list]
Height | 458 mm |
Length | 132 mm |
Weight | 3.3 kg |
Width | 220 mm |
