Covidien - Nellcor PM100N
by Covidien
Vital Signs/Multi-Parameter
The PM100N pulse oximetry monitor is a compact, portable patient monitoring system designed for both hospital and non-hospital environments. Its lightweight form factor and integrated carry handle allow for easy bedside placement and transport, making it suitable for home care, sleep studies, and remote monitoring applications. The PM100N includes dedicated home care and sleep study modes, along with password-protected access to support safe operation by non-clinical users.
Equipped with Nellcor™ digital signal processing (DSP) technology, the PM100N delivers accurate and reliable SpO‚ and pulse rate measurements even in challenging conditions such as low perfusion, patient motion, and signal interference. Advanced SatSeconds™ alarm management helps reduce nuisance alarms by differentiating clinically significant events from transient desaturations. Additionally, the system supports data download and export for post-study review, trending, and further clinical or engineering analysis, making it a practical solution for biomedical engineers managing multi-environment patient monitoring systems. (Generated by AI)
FORUMSView All (14)
-Mustansar Hussain
Wed Nov 22 2023
Technical support number
I been trying get technical support nellcor number. I have tried putting code in but they are not working.
Equipment: Covidien - Nellcor PM100N
Sun Oct 08 2023
Standard mode
How do I switch to standard mode to set alarms
-Mark K Brennan
Wed Aug 16 2023
EEE901 Error Code
Hi All, Can anyone shed a light on what causes the above error. I have searched everywhere and can find no mention of it?
  • Displays plethysmographic waveforms, pulse amplitude and real-time SpO2 and pulse rate data
  • 96-hour trend memory with data captured every four seconds for quick review of changes in patient status
  • Includes SatSeconds alarm management, a clinician-controlled feature that has been proven to reduce nuisance alarms
  • Password protected homecare and sleep study modes
  • Both homecare and sleep study modes meet IEC 60601-1-11 for home health equipment to promote the safe and effective use of the monitor by lay users in the non-hospital setting
Height82 mm
Length 155 mm
Pulse Rate Range20-250 BPM
Weight1.5 kg
SpO2 Range1-100%
Width255 mm
