Landwind Medical - Mirror 2
Mirror 2 is a stable and reliable ultrasound system, putting quality ultrasound technology well within the reach of any private practice.FORUMSView All (4)
3Replies7 months ago | NEED POWER SUPPLY UNIT How can i get the power supply unit for landwind mirror 2 need to replace mine. Equipment: landwind mirror 2 Reply |
3Replies2 years ago | MANUAL NECESITO MANUAL PARA ECOGRAFO LANDWIND MIRROR 2 Reply |
0Replies5 years ago | The equipment starts but after sometime loose images from the transducer. This equipment use to start normally and after an hour or two the images from the transducer is lost. The equipment still recognizes the transducer that is connected (it has two, convex and micro-convex) but there is no reception on the screen of what ever you put in front of the transducer after it fails. Right now the problem is that from the beggining you can't see any image from the transducer and intermittently recovers the signal but get lost again. I check the psu and everything seems to be ok, and there is no voltage drop when the problem appears . Somebody can help me with this?Reply |
[list] [*] PIHI: Pulse Inverse Harmonic Imaging - PIHI is a modality that distort the fundamental pulse signal and extract the pure broadband harmonic signal due to its highest amplitude. Thus PIHI can improve image overall uniformity with high resolution and high penetration than traditional THI (Tissue Harmonic Imaging). [*] Digital Fine Focusing - The interval of traditional dynamic focusing is more than 0.154mm while digital fine focusing interval is less than 0.02mm. Each sample point can be precisely focused so as to effectively improve the superficial image. [*] LanSRI: Speckle Reduction Imaging - LanSRI means decompose the image to a group of smaller ones in pyramid structure, analysis the texture information to remove speckle noise in different scales and then reconstruct the image after the noise suppression. LanSRI can help to enhancesmooth along preferred edge direction, reduces variation within speckle region, and maintain local mean gray scale level. [*] LanBeam: Spatial Compounding Imaging - With LanBeam, the user can scan multiple coplanar images from different angles and combine into a single image in real time, one angle will be perpendicular to round or oval reflector. Doctors can get greater smoothness of borders and interfaces, improved contrast resolution and border detection. [*] Trapezoidal Imaging - Trapezoidal Imaging Extend the FOV of scanning. Landwind Medicals trapezoidal Imaging is available on convex, linear and endocavity transducers. [*] Dual Live Display - Dual live displays with grayscale reference image and color Doppler image. [/list]
