Rigel Medical - SafeTest 99
An affordable electrical safety analyzer with patient lead leakage testingThe SafeTest 99 is a simple, rugged and cost-effective medical safety analyzer for general electrical safety and patient lead testing. With a large color display and a color coded user iterface, it's easy to select the required test at a touch if a button. The SafeTest 99 is perfect for high volume testing of medical and laboratory equipment, with or without patient leads. Thanks to the easy to use interface and simple layout, and a fast selection of test routines, testing has never been so easy and dependable!Compact and portable with a full range of safety tests in accordance with NFPA-99, the SafeTest 99 enables compliance and reduces downtime in medical and laboratory equipment.Full manual control offers the benefit of executing only those specific tests that are required and provide the user with full control of the power cycles, making testing simple, easy and fast.An automatic warning of secondary ground paths ensures users are made aware when invalid readings are made, thus ensuring correct and accurate test results first time, every time.
0Replies4 years ago | Rigel SafeTest 99 Electrical Safety Analyzer Demonstration Video The SafeTest 99 is a compact and reliable electrical safety analyzer which allows you to carry out patient lead leakage testing in accordance with NFPA-99.It features accurate high current, low energy ground continuity testing with secondary ground warnings to ensure valid tests.You can quickly step-through test routines with minimized power breaks and have manual control of fault conditions. The SafeTest 99 comes complete with a patient lead adapter box and a protective carry case.Reply |
VIDEOS
[list] [*] Patient lead leakage testing in accordance with NFPA-99. [*] Accurate high current, low energy ground continuity testing. [*] Fast step-through of test routines with minimized power breaks. [*] Secondary ground and isolated supply warnings to ensure valid tests. [*] Manual control of fault conditions. [*] Clear and vibrant color display. [*] Universal voltage input. [*] Patient lead adapter box included. [*] Ready to use, box to bench. [*] Supplied with protective carry case. [/list]
