Hologic - Selenia Dimensions
by Hologic
Clinically superior. Low dose.
The revolutionary Selenia Dimensions system, which has set the new standard in mammography screening.                        Hologic has progressed breast cancer screening even further by producing 2D images from breast tomosynthesis data using C-View software, resulting in a Low Dose Genius 3D MAMMOGRAPHY exam with superior clinical performance compared with 2D alone.3                        This Low Dose Genius 3D MAMMOGRAPHY exam is performed in a rapid <4 second scan time for greater patient comfort; and, low patient dose due to the elimination of 2D X-ray exposures. The generated 2D images and 3D slices are reviewed together to make a clinical decision or diagnosis as part of the Genius 3D MAMMOGRAPHY screening exam.
FORUMSView All (20)
-ATW
Sun Dec 21 2025
Mamografo
Tengo estos errores 25:8 y 25:11 error de captura de imagen y 25::11 filament calibration is recommended
Equipment: Hologic selenia dimensions
Translation: I'm getting these errors: 25:8 and 25:11 image capture error, and 25:11 filament calibration is recommended.
-Mise2376
Sat Aug 09 2025
It is possible to make an exposure without the digital receptor?
Hi Everyone, I have some troubles with the digital receptor of the Lorad Selenia, so I was thinking If it is possile to deactivate the detector for use just the generator and make exposures using an external detector?
I´ve already use the S7 of the host to put the brick and array on bypass but It doesn´t work. Does any one try it?
-mohamed nagy
Sat Mar 08 2025
Detector offline
Hello everyone i habe selenia dimension error 8:39 fiber pci card green led not on ineed help technical support and installation manual for detector.
[list]            [*] Exceptionally sharp images            [*] Seamless transition between imaging modes            [*] Sophisticated user tools that simplify operation            [*] Advanced clinical applications            [*] Tomosynthesis-guided biopsy            [*] Ergonomic design for patient comfort and ease of operation            [*] A 41% increase in invasive breast cancer detection                        High-resolution display:            [*] Images that can be instantly viewed on a 2 MP or 3MP DICOM-calibrated display, providing exceptionally fine detail.            [*] Allows prior breast imaging studies to be recalled, making it possible to view new and prior images side-by-side.                        Optimized face shield:            [*] Retractable to help when positioning patients.            [*] Stationary during 3D™ imaging, allowing patients to be positioned as they are for 2D imaging.                        FAST Paddle system:            [*] Conforms to natural contours of the breast, providing greater comfort to the patient and more even compression across the entire breast.            [*] All paddles used for 2D and 3D™ imaging.            [/list]
