Olympus - UHI-3
by Olympus
Clear interior space for clear-thinking procedures. When the UHI-3 is connected to the SonoSurg Ultrasonic Surgical System, mist evacuation begins simultaneously with ultrasonic output. Just press the foot switch (optional) of the SonoSurg generator and smoke and mist will be evacuated, so you can keep your clear view during surgery. Better views and more ergonomic reduces stress in the OR and improves the quality, safety and speed of each procedure.
2RepliesWed Aug 18 2021 | Service interval What is the service interval for Olympus UHi-3 InsufflatorsReply |
1ReplyThu Oct 10 2019 | Request to obtain documentation about UHI 3 olympus insufflator Hello everyone, I'm looking for a service manual or operators manual for UHI 3 Olympus Insufflator. If you have any documentation, please, could you send me a hyperlink for download documentation. Thank you all in advanceReply |
1ReplyMon Jan 23 2017 | Services manual Just need services manual. Thank you Reply |
Powerful 35 L/min. insufflations The UHI-3 features a powerful 35 L/min. high flow gas-supply. It can quickly respond to gas leakages to return to the preset pressure level.[list] [/list] Automatic relief When abdominal pressure becomes too high, a warning lamp and an alarm are activated, and a pinch valve on the suction tube opens automatically to release excess pressure.[list] [/list] Low noise design Noise is kept especially low through an innovative mechanism in the electromagnetic valve.[list] [/list] 3 main flow settings You can quickly set flow rate to programmed Low, Medium or High mode.[list] [/list] Check critical data at a glance Actual and preset pressures are displayed simultaneously. You can easily monitor necessary information, while remaining focused on what you are doing.[list] [/list] Connectable to medical gas pipeline The UHI-3 unique pressure control mechanism let you connect it to your hospital medical gas pipeline, eliminating the need for handling heavy, inconvenient gas cylinders.
