Galix Biomedical - Pace Star
Galix PaceStar Multiprogrammable External PacemakerThe multiprogrammable External Pacemaker Galix model PaceStar has 3 methods of tachycardia termination and a graphic display to show simultaneously all programmed parameters and intracavitary ECG signal. Pulse rate, pulse width, pulse amplitude, sensitivity, refractory period and hysteresis can be programmed to achieve the highest pacing performance. All cardiac parameters used in the pacing mode are accessible by one or two keys of the keyboard. Extensive testing on this module during production makes it very reliable on the field. It has a defibrillation, electromagnetic interference and software failure protection system. Small in size, ergonomic and lightweight, it has a lot of measurement features and statistics that make it unique in today's market.
- Pacing for Bradycardia and Tachycardia Support
- Graphic Display for Intracardiac ECG monitoring
- Three methods of Tachycardia Termination
- Past Events Data Logging
- Multiprogrammability: Rate, Amplitude, Sensitivity, Width, Refractory Period and Hysteresis.
- Proven ultra high reliability
- Powered by two AA batteries
- Acoustic and visual alarms
- Protection against Electromagnetic Interference and Defibrillation
- It can operate uninterruptedly even while batteries are being replaced.
Pacemaker Type | External Invasive |
External Pacemaker Pacing Programmable Parameters: Normal Rate: 30-200ppm |step:5ppm| Accuracy:+/-5% Pulse Amplitude: 0.2V-10V | step:0.2V | Accuracy:+/-5% Sensitivity: 0.2mV-12mV | step: 0.2mV | Accuracy:+/-0.2mV Refractory period: 200ms-400ms | step: 5ms | Accuracy:+/-1.5% Pulse Width: 01ms-2ms | step: 0.1ms | Accuracy: +/-0.2% Hysteresis: 0 - 5 - 10 - 15 - 20ppm Emergency: SSI(AAI/VVI) | R=70ppm | A=10V | S=2.4mV | W=1ms EMI Protection: auto-switching to AOO/VOO with acoustic alarm Defibrillation Protection: Up to 400Joules Software Failure Protection: auto-switching to Emergency mode High-rate Operation (overdrive): 120ppm-600ppm | step: 10ppm | Accuracy:+/-3%. General: Enclosure: Shock-resistant ABS plastic with sliding door for battery compartment. Only one battery can be changed at a time, Galix external pacemaker can temporary operate with 1 AA, 1.5V Alkaline battery Dimensions: Length:6.53"(166mm), Width:3.46/2.75"(80/70mm), Height: 0.87"(22mm) Weight: 11.5oz.(320g) Power Source & Battery Life: 2-AA Alkaline batteries. Minimum of 20 days of continuous pacing Extender Cable: Compatible with FDA Standards for temporary catheter lead wire Keyboard: Polycarbonate metal-dome tactile-free membrane Display: Graphic Liquid Crystal Display Accessories: Galix external pacemaker set includes a shock-resistant carrying hand-bag, 2,1.5V AA Alkaline batteries, extender cable, arm strap, waist strap, and instruction manual. Measurements and Statistics: R-R/P-P Interval: 5ms-2s Patient Frequency: 30bpm to 300bpm P-Wave or R-Wave Amplitude Pacing clock: Up to 10 days | Accuracy:+/-0.01% Pacing Percentage: ratio between the total number of paced beats, and total number of paced beats plus spontaneous beats Low Battery Indicator: Acoustic and visual alarm is activated once batteries cannot withstand 3 hours of operation
