Schaerer Mayfield - Arcus 701
by Schaerer Mayfield
Featuring the Schaerer offset cantilevered base for maximum imaging access, the arcus is designed for general surgery as well as specialty use.
[list]      [*] Static weight capacity of 1100 lbs (800 lbs dynamic)      [*] 23” Low height for seated or bariatric patients      [*] Cantilevered base provides unsurpassed imaging area      [*] Neuro Speed button for exact positioning      [*] 5th wheel for 360° rotation      [*] Wide range of accessories allows the Arcus to be transformed into versatile table perfect for orthopedic, bariatric, urological, neurosurgical or spine procedures.      [/list]
Weight without head and leg plates: 290kg      Length without head plate: 695 mm      Length with head plate: 990 mm      Width of Table Top: 520 mm      Total Width (with side Rails): 580 mm      Width with lateral table extension: 880 mm      Maximum patient weight: 360 kg      Height adjustment with patient weight up to 260 kg (top edge pad, blocked table): 595 - 1200 mm      Height adjustment with patient weight over 260 kg (top edge pad, blocked table): 595 - 1000 mm
