ZEISS - VISULAS 532s
by ZEISS
Fully integrated laser workstation
The VISULAS® 532s is a powerful, diode-pumped solid-state laser. Its built-in thermoelectric cooling system ensures excellent temporal stability of the laser power and thus meets the requirements for reproducible clinical results. The VISULAS 532s is designed in particular for retinal photocoagulation, trabeculoplasty and iridotomy for treatment of glaucoma. The VISULAS 532s with the VITE option is primarily useful for multi-spot panretinal and grid photocoagulation.
FORUMSView All (18)
-G.E.
Thu Nov 13 2025
Switch for moving table up/down
Switch for moving table up and down is not working, in case press switch for moving down it is not responding at all, when press switch up it not moving at all, but when release switch it shake table a bit, like it would like to move up or the mechanism is stuck. have any the same experience and how this problem can be solved? thank you for any help.
Equipment: ZEISS VISULAS 532s
-MSALAZAR
Thu Jul 03 2025
modificar parámetros
Hola a todos, tengo un visulas 532s de zeiss el cual no me deja modificar configuración de valores de umbral y máxima corriente (Threshold and Max.current) en modo servicio, alguien sabe cómo hacer estas modificaciones
Equipamiento: ZEISS - VISULAS 532s
Traducción:
Hello everyone, I have a Zeiss 532s display that won't let me modify the threshold and maximum current settings in service mode. Does anyone know how to make these changes?
Equipamiento: ZEISS - VISUALS 532s
-Giusimo
Wed Mar 12 2025
service manual
I would need the service manual for the zeiss laser 532
Equipment: ZEISS - VISULAS 532s
[list]      [*] Gentle laser treatment - The ParFocus™ zoom system delivers a homogeneous, sharply defined and reproducible laser spot on the retina and minimizes heat-related side effects on the patient's cornea.      [*] Significantly reduced treatment times - The VISULAS 532s VITE can operate in multi-spot mode without compromising the outcomes      [*] Navigating with fingertip precision - The electronic micromanipulator allows sensitive, synchronous laser beam positioning and slit lamp illumination      [*] True-to-color slit lamp image - The active ClearView™ safety filter not only protects the physician but also provides a true-to-color slit lamp image      [*] Solid performance in the operating room - A perfect duo together with the [url=https://www.medwrench.com/equipment/12632/zeiss-meditec-opmi-vario-700]OPMI LUMERA® 700[/url] surgical microscope.      [/list]
Height150 mm
Length 400 mm
Weight14 kg
Wavelength532 nm
Width300 mm
