Skytron - 3502
by Skytron
With 21” of top slide, the patient can be effortlessly moved throughout the imaging window at the simple command of the hand-held control. The low profile base will not get in the way of movable imaging equipment and the low table height can accommodate seated surgeons. With its impressive 700 lb lift capacity, this table is also an ideal solution for bariatric cases.
2Replies7 years ago | Skytron 3502 repair manual Hi- Does anyone happen to have a copy of the Skytron 3502 service manual? Reply |
[list] [*] 21” horizontal slide [*] 700 lb capacity [*] 26-44.875” height [*] 20° tilt [*] 25° trendelenburg [*] 20° reverse trendelenburg [*] kidney bridge [/list]
