Skytron - 3602
by Skytron
[list] [*] 23” top slide [*] 9 1/2” slide to head and 13 1/4” slide to foot [*] 1,000 lb lift and 800 lb articulation weight capacity [*] Removable back and leg sections for quick accessory attachment and positioning [*] Power beach chair positioner for one-touch set-up [*] Durable stainless steel base is easy to clean [*] 243/8”-431/4” adjustabletable height [*] 30° lateral tilt [*] 30°Trendelenburgandreverse Trendelenburg [/list]
Length: w/o head rest 69 1/2”, 1,765mm Length: with head rest 82 1/8”, 2,086mm Width: 19 5/8”, 500mm Width with side rails: 21 7/8”, 555mm Height: 24 3/8” to 43 1/4”, 620 - 1,100mm Power Kidney Bridge: 5 3/4”, 146mm Lift Top slide/head: 9 1/2”, 245mm Top slide/foot: 13 1/4”, 335mm Max. permissible load: 1,000 lb (450kg) lift; 800 lb (360kg) Articulation
