Skytron - 6302 Elite
by Skytron
Surgical Table with 210 Degree Top Rotation
The 6302 Elite surgical table provides up to 210° top rotation, allowing you to easily maneuver your patient according to imaging requirements, anesthesia access and positioning preferences. This rotation eliminates the need to reverse the patient on the table, thereby improving patient and staff safety in the OR. Unlike other top rotation tables available in today’s market, the 6302’s surface turns independently of the table base, giving you maximum foot room and imaging access. The impressive 1,000 lb lift capacity makes the 6302 an ideal solution for bariatric cases.
0RepliesFri Dec 12 2025 | Level switch replacement - skytron elite 6302 table In case anyone needs it https://youtube.com/shorts/dGJiS0PG2p0?si=REUXQ4UcRW6OIL1y Reply |
| Lateral Tilt | 30 degrees |
| Patient Weight Capacity | 1000 lift and 600 lbs articulation |
