STERIS - 5085
by STERIS
The STERIS 5085 General Surgical Table quickly and easily adapts to virtually every surgical specialty.
Quick, one-touch patient posturing is enabled by the 5085 Surgical Table's intuitive hand control's pre-programmed positions for rotation and beach chair for easy set up. The surgical table’s easy-to-read LCD window telegraphs table positioning data to caregivers, even in a darkened room.Higher weight limit, exceptionally low height and a large imaging area means no more inflexible, dedicated specialty tables.
FORUMSView All (3)
-scottde
9 months ago
manual
service manual needed
Equipment: STERIS - 5085
-Bryan99
4 years ago
error code 10
Good day all. Hope someone can help me out a bit. I have a Steris 5085 OR table that will not lock to the floor but all other functions work. An error code 10 is displayed on the hand controller. Any suggestions would be helpful. Reply
-Forgtronix
5 years ago
I need help
I need an information about a Virtual Anatomy Table. Where can I find this equipment? Doesn't matter if it's new or used. Thank you for your help. Best regards.Reply
  • Accommodates virtually all patients with generous weight and height ranges
  • Provides unrestricted perineal access with removable leg section
  • Optional Featherweight Leg Section complies with AORN Safe Handling principles
  • Enhances lateral procedures with a powered, radiolucent kidney elevator
  • Provides outstanding access for C-arm, permitting clear high-quality images crucial to MIS, cardiothoracic, orthopedic and neurosurgical procedures
  • Facilitates quick and safe patient positioning with an easy-to-use, easy-to-read hand control
  • Contours to virtually all patient postures with four section tabletop
  • Compensates for uneven OR floors with self-leveling floor locks
  • Prevents sectional and table base collisions with the Auto Limit Sensor
  • Compatible with a wide array of previously purchased accessories
Table Length: 81" (2057 mm)
Table Width: 20" (508 mm) (28° with extenders)
Table Height Range: 22.8" to 42.5" (581 to 1080 mm)
Table Slide Range: 9" (227 mm) to head, 9" to foot (18 inches total)
