Buffalo Filter - PlumeSafe Whisper
by Buffalo Filter
Smoke Evacuation System
Featuring whisper-quiet technology, a convenient fold-down handle, and an up-right base with hidden wheels this unit has been a hospital favorite as it is easily pulled from room to room. PlumeSafe Whisper is Buffalo Filter's quietest smoke evacuator. The PlumeSafe Whisper features our whisper-quiet technology and comes standard with a convenient fold-down handle and hidden wheels to move it easily from room to room.
FORUMSView All (3)
-Duff Burkes
Wed Jul 24 2019
manual needed
service and op manual manual needed Reply
-Duff Burkes
Wed Jul 24 2019
manual
service and op manual Reply
-KimG
Thu Mar 22 2012
Info
How much is this Unit.  Is it still in original box? Does it have a warranty.  Does it come with filter, tubing, etc?
  • Extremely Quiet
  • Portable
  • Provides 0.12 micron filtration @ 99.9995% efficiency
  • Easy to operate
  • LED Display of filter life and suction power
  • Simple filter changes
  • Noise Levels- minimum power < 39 dBA @ maximum power < 59 dBA
  • Dimensions (L x W x H)14in x 14in x 20in 36cm x 36cm x 51cm
  • Flow Rates with standard tubing sizes 1- 1/4" (32 mm) - 40 CFM (1133 LPM) 7/8" (22 mm) - 33 CFM (935 LPM) 1/4" (6 mm) - 4.4CFM (125 LPM)
  • Electrical Environments-The PlumeSafe Whisper is available in 100/120 Volt 50/60 Hz and 220/240 Volt 50/60 Hz configurations
  • Static Suction In. H20 (mbar): 75 (187)
  • Weight28 lbs (13.0 kg)
  • Certifications UL, cUL, CE
  • Warranty 1 Year Full Warranty
  • Ordering Information PlumeSafe Whisper Smoke Evacuator 100/120 Volt System - PART # PSW0602 220/240 Volt System
  • PART # PSW0602/220 Filters and tubing sold separately.
