Meditech - CMI-120
by Meditech
Improve the procedural efficiency with its superior light source
The Halogen Operation Lights are designed to assists during critical operations where focused source of bright light is required.
-BobShow
7 years ago
Wiring Diagram
looking for a wiring diagram for above.Reply
[list]    [*] This light execute by remote.    [*] Dichoric glass reflector with cold mirror technology reduces heat and improves light output.    [*] Spring arm made of stainless steel.    [*] Equipped with reserve bulb, which activate automatically in case of main bulb brakes down.    [*] Sterilizable handle helps to adjust the focus dia.    [*] Inbuilt digital control panel helps to adjust the Intensity from 10 to 100%.    [*] Aerodynamic shape & laminar compatible.    [/list]
Lighthead Diameter504 mm
Illumination Intensity at 1m: 90,000 Lux
