Buffalo Filter - Porta PlumeSafe 604
by Buffalo Filter
Designed for small offices and clinics. It is light enough to easily move from room to room or be placed on a table. The Porta PlumeSafe 604 is extremely lightweight & portable, economical and quiet. It offers 0.12 micron filtration that is 99.9995% efficient and features a LED display of filter life as well as simple filter changes.
1ReplyThu Feb 16 2023 | bad motor does anyone know where a person can get a new or rebuilt motor for the above smoke evac. system? Equipment: Buffalo Filter 604 smoke evacuation system Reply |
0RepliesThu Oct 22 2020 | RFID antenna? The 2 pin connector from the wire looping around the filter has been dislodged from the PC board and is just hanging loose inside the compartment. I am unsure where to reattach. No obvious point and without schematic or manual, the filter is useless. I have pictures. Many thanks for any advice. Reply |
1ReplyWed Jul 24 2019 | manual needed service and op manual manual needed Reply |
[list] [*] Extremely lightweight & portable [*] Easy to operate [*] RFID technology automatically tracks filter life so you don't have to! (patent pending) [*] Economical [*] Provides 0.12 micron filtration @ 99.9995% efficiency [*] LED Display of filter life and suction power [*] Simple filter changes [*] Quiet [/list]
| Height | 10 in |
| Length | 18 in |
| Width | 6.5 in |
Performance References* Noise Levels @ maximum power < 59± 2 3dba* Flow Rates with standard tubing sizes 1- 1/4" (32 mm) - 48 CFM (1358 LPM)* 7/8" (22 mm) - 36± 2 (1219± 28.3)* 1/4" (6 mm) - 2.8 CFM (82 LPM)* Electrical Environments The Porta PlumeSafe 604 is available in 100/120 Volt 50/60 Hz and 220/240 Volt 50/60 Hz configurations Static Suction In. H20 (mbar): 91.5 (227) Weight 18.1 lbs (8.2 kg) Certifications UL, cUL, CE
