Siemens - ADVIA XPT
by Siemens
The workload demands on your laboratory and staff are continually increasing. To stay ahead of these growing demands, you need an easy-to-use chemistry system that maintains continuous operation and delivers powerful productivity for improved efficiency. The ADVIA® Chemistry XPT System is engineered for continuous operation and timely, accurate results. The system’s advanced software and VeriSmart® Technology provide accurate testing for predictable, timely, and reliable results to meet your expanding workload.
1Reply8 years ago | User Manual Please upload Advia XPT chemistry user manual.Reply |
[list] [*] Intuitive, icon-driven user interface for simplified training and operation [*] ISE module designed for high throughput without the need for routine maintenance [*] Concentrated reagents provide a high number of tests onboard for long walkaway times [*] Status light displays system alerts visible from anywhere in the laboratory [*] Designed for automation; requires no additional robotics [*] Point-in-space technology enables direct-from-track sampling [*] Onboard aliquotting allows sample to be immediately released to the next workstation, driving productivity and improving laboratory turnaround time (TAT) [*] Comprehensive menu of 116 assays (June 2014); supports up to 2400 tests per hour (1800 photometric plus 600 ISE) to provide consistent and predictable TAT [*] Micro-volume technology reduces blood-draw requirements by using a single 30 ΜL sample for up to 15 tests [*] Quick release of sample tubes allows parallel tube processing and rapid, predictable TAT [*] Aliquot retention allows automated, preprogrammable dilution, reflex, and rerun testing without calling back the sample [/list]
Height | 135 in w/out monitor; 149 |
Sample Capacity | 84 |
Length | 99 in |
Weight | 725 kg |
Light Source | 12V, 50W halogen lamp |
Sample Types | Serum, plasma, urine, whole blood, and CSF, assay-dependent |
Width | 177 in |
