Beckman Coulter - Unicel Dxi 800
Beckman Coulter's Unicel Dxi 800 is one of the premier immunology systems.
0Repliesa year ago | service manual service manual documentsReply |
Standardized design of reagent packs
- Compatibility across immunoassay systems
- Minimal reagent preparation or reagent management required
- Bar-coded, liquid, ready-to-use reagents
- Onboard capacity of 50 refrigerated reagent packs enhance flexibility — configure the system menu to match testing requirements
- A broad menu across a wide variety of disease states enables your laboratory to consolidate workstations
Simplified operation improves productivity
- Load reagents and all consumables ‘on-the-fly’, without using the console computer or pausing the instrument, minimizing intervention
- Easy-to-follow pictogram and indicator lights show which supplies need replenishment
- Large volume supplies maximize walkaway capacity
Streamlined sample handling
- Load capacity of 120 samples at once; continuous loading capability
- Racks are compatible with SYNCHRON LX systems, decreasing sample handling across multiple systems
- Racks can be loaded directly from the centrifuge, reducing manual processes
- Routine sample loading can be interrupted to load STAT samples quickly
- “Point-in-space” pipetting technology aligned with NCCLS guidelines allows integration with laboratory automation systems
- Releases primary tube in less than five minutes for testing in other areas of the lab
On-board aliquot capability
- Automatically creates aliquots based on the volume of requested tests plus any additional volume that may be required for user-defined reflex or re-run test scenarios
- System stores aliquots for up to three hours in a patented, refrigerated low-evaporation compartment
- Simplifies inventory management — utilize same type of vessel for aliquots and reactions
Proven chemiluminescent detection delivers excellent precision and sensitivity with a broad dynamic range
- System supports multiple assay protocols to ensure peak assay performance
- Magnetic particle separation with chemiluminescent detection delivers exceptional clinical performance
- Rapid assay kinetics improve TAT
Innovative system delivers powerful efficiency
- Intuitive operator interface, with touch screen capability, maximizes efficiency
- Auto-matched pipettors work in parallel to deliver sample and reagent into the reaction vessels – and achieves a peak throughput of 400 tests per hour
Height | 67 in |
Length | 38 in |
Weight | 1390 lbs |
Width | 68 in |
