Getinge - Castle 2410
by Getinge
Surgical Field Light
The Castle 2410 MB Surgical Field Light consist of a light head and counterbalance arm assembly, support posts, and base assembly. Arm pivots enable the light head to be positioned for surgical procedures. Light head pivots provide tilt and rotational adjustments.         The light head assembly contains the optical system of the light. The reflector directs a high intensity pattern onto the patient. A blue-green filter surrounding the light source color-corrects the light and filters heat. A frosted lens diffuses the light beam.         The light head and counterbalance arm assembly is mounted on a vertical post attached to he base. The base is equipped with wheels for portability.         The light can be operated from a 115V or 230V, 56 or 60 Hz power source, from the internal backup battery, or from an external 24V battery.
FORUMSView All (3)
-DFMK6
7 years ago
Replacement bulb socket needed
Does anyone know where I can find a replacement bulb socket for the Castle 2410? Thanks.Reply
-Beondu308
8 years ago
Replacement parts
Where can I find a replacement glass heat filter for the Castle 2410MB?Reply
-Ty
8 years ago
Service Manual
Hi, Anybody have a source for a service manual for a Castle 2410 OR light? We need to identify any OEM recommendations on periodic maintenance, complements of the beloved CMS ruling. ThanksReply
