CritiCare - VitalCare 506N3
The VitalCare 506N3 monitor is designed to travel everywhere you do, with a lightweight monitor and integrated carry-handle.Spot-check or continuously monitor three critical parameters; (SpO2, NIBP, and predictive temperature) on neonates to adults with a single monitor. Advanced technology—including CSI DOX™ or Nellcor OxiMax™ pulse oximetry, CSI ComfortCuff™ NIBP, and FILAC® FasTemp® predictive temperature—and exceptional ease of use make our 506N3 series monitors the perfect solution to your clinical challenges. Designed to travel everywhere you do, the lightweight 506N3 monitor with integrated carry-handle attaches quickly and easily to IV pole mount or rolling stand. Available in eight configurations—with or without predictive temperature, with or without internal printer, with CSI DOX™ or Nellcor OxiMax pulse oximetry—the 506N3 series provides maximum versatility and cost-effectiveness.
FORUMSView All (9)
1Reply7 years ago | Accuracy Criticare 506N3 Hi, I have just received the calibration kit for the above and the first UUT calibrated fine but reads more than 10% low in the accuracy test? IS there adjustment for this or is it now RTB? Thanks KelvinReply |
1Reply7 years ago | frozen monitor I have a criticare 506NT3 series. was in the middle of a procedure when the monitor froze. we are unable to turn it off and it's not making any readings. Can you help me. What do you think is going on? and how can I fix it/ Reply |
0Replies8 years ago | need battery replacement battery need replacing how to order Reply |
[list] [*] Optional DOX or Nellcor OxiMax SpO2 technology. [*] Proprietary ComfortCuff NIBP measures on inflation for faster, more comfortable readings. [*] Optional FILAC FasTemp predictive temperature with predictive and monitoring modes delivers quick, accurate measurements. [*] Audible and visual alarms provide instant notification. [*] Lightweight design and versatile mounting options—adapts readily to department and transport requirements. [*] Optional internal printer for demand, automatic interval, or trend reports. [*] Smart battery management with rechargeable sealed lead acid battery. [/list]
Height | 8.7 in |
Length | 6.5 in |
Weight | 6.95 lbs |
Printer | Thermal array |
Temperature Range | 0 to 45 °C |
Width | 7.1 in |
Trend Memory Memory: Last 24 hours Parameters: SpO2, pulse rate, NIBP, temperature Report Types: Single Patient or Multi-patient; Selectable formats Alarms Indication: Audible; Visual Volume: 10 levels or Off Silence: Yes; 2 minutes or permanent Non-Invasive Blood Pressure Technique: Oscillometric measure upon inflation Measurement Time: 240 bpm Accuracy (OxiMax only): Greater of ±1bpm or ±1%, of reading Unspecified for 240 bpm Update Time: Every second Resolution: 1bpm Pulse Volume: 10 levels or Off
