ABI - 3730
by ABI
The 3730 DNA Analyzer system is engineered for highly reliable, unattended operation of up to 48 hours (applies to modules with run times longer than 30 minutes). Automation features which minimize the need for operator intervention and decrease the risk of human error include an integrated plate stacker, internal bar code reader, and onboard polymer delivery system.
The high signal-to-noise ratio ensures you get high-quality data — even when users use low-concentration samples and reagents. Labor-saving automation features minimize hands-on time and enable you to analyze more data more efficiently.
The enhanced optical design provides a higher signal-to-noise ratio and a more uniform signal profile across the array. This design, combined with the new, advanced polymer, enables the longest read lengths of any available system, and provides enhanced color balance for streamlined genotyping sample handling. In addition, exceptional sensitivity enables higher success rates across a wider range of sample templates and concentrations than other currently available systems.
| Height | 89 cm |
| Length | 73 cm |
| Weight | 180 kg |
| Width | 100 cm |
