CritiCare - 506NV3
by CritiCare
Spot-check or continuously monitor three critical parameters; (SpO2, NIBP, and predictive temperature) on neonates to adults with a single monitor. Advanced technology—including CSI DOX™ or Nellcor OxiMax™ pulse oximetry, CSI ComfortCuff™ NIBP, predictive Alaris TurboTemp® temperature—and exceptional ease of use make our 506NV3 series monitors the perfect solution to your clinical challenges.
The 506NV3 TurboTemp® series is designed for facilities that are maintaining compatibility with IVAC type P850A probe covers and Alaris TurboTemp® probes. The lightweight 506NV3 monitor with integrated carry-handle attaches quickly and easily to IV pole mount or rolling stand. Available in configurations with or without internal printer, with optional CSI DOX™ or Nellcor OxiMax pulse oximetry—the 506NV3 series provides maximum versatility and cost-effectiveness.
0Repliesa day ago | service manual calibrationReply |
1Reply4 years ago | reset time and date Reply |
Non-Invasive Blood Pressure:
Technique:Oscillometric measure upon inflation
Measurement Time: 240 bpm
Accuracy (OxiMax only): Greater of ±1bpm or ±1%, of reading
Unspecified for 240 bpm
Update Time: Every second
Resolution: 1bpm
Pulse Volume: 10 levels or Off
Temperature
Type: Alaris TurboTemp®
Method: Predictive or Continuous
Channels: 1
Predictive Mode Range: 96.0° to 106° F (35.6° to 41.1° C)
Continuous Mode Range: 80:0° to 106° F (26.7° to 41.1° C)
Accuracy:±0.2°F (±0.1°C) (measured in calibrated water bath in continuous mode)
Resolution: 0.1° F or 0.1° C
Response Time: 10 seconds typical (oral measurements)
Probes:CAT1544 Oral, CAT 1545 Rectal
Probe Covers:CAT 447 (P850A)
Alarms:
Indication: Audible; Visual
Silence: Yes; 2 minutes or permanent
Trend Memory:
Memory: Last 24 hours
Parameters: SpO2, pulse rate, NIBP, temperature
Report Types: Single Patient or Multi-patient; Selectable formats
Displays:
Type: LED
Parameters: NIBP, SpO2; temperature, pulse rate; pulse bar
Status: Alarm Silence; Sensor; Low Battery; External Power; Patient Size
Text: Alphanumeric LCD
Languages: English, French, German, Italian, Portuguese, Spanish
System Output:
Com Port: Serial, RS 232-compatible
Printer:
Type: Thermal array
Tabular Mode: 1 - 60 minute intervals; 2 - 24 hour intervals; Auto on BP; Auto on Alarm, Off
Mechanical:
Weight: Base unit with battery: 6.95 lb; 3.15kg
Size: Base unit:8.7" (H) x 7.1" (W) x 6.5"; (D); 22cm (H) x 18cm (W) x 16.5cm (D)
Power Requirements:
Voltage: 100 to 240 VAC, 50 to 60 Hz
Battery: Sealed lead acid; Life: 8 hours
Rechargeable: 6 hours
Environmental:
Operating Temperature: 32° to 113° F; 0° to 45° C
Storage Temperature: 23° to 122° F; -5° to 50° C
Operating Humidity: 15% to 90%, non-condensing
Classification:
Type of Protection: Class I equipment
Degree of Protection: Type CF defibrillator-proof equipment
Protection against Ingress: IPX1 rating, Drip-Proof Equipment
