CritiCare - nGenuity 8100E(P)
The nGenuity 8100E(P) patient monitor is the perfect choice for busy departments demanding accurate, reliable performance.Compact and lightweight, the nGenuity 8100E(P) patient monitor can monitor patients in virtually every department - at bedside or in transit.The innovative user interface features simplified menus and dedicated function keys for timely set-ups.The big, bright display with large numerics can easily be seen, even from across the room. The nGenuity 8100E(P) patient monitor mounts quickly and easily to walls and rollstands.
FORUMSView All (4)
0Repliesa year ago | manual I am looking for a Jpeg manual Equipment: CritiCare - nGenuity 8100E(P) Reply |
0Replies6 years ago | 8100 isn't recognized by service software Any common troubleshooting tips for getting an 8100 to communicate with NiBP service software on a PC? USB adapter cable is set to COM3 and attached to the 8100's "COM2" port(tried the COM1 Port on the 8100 as well). Any help would be appreciated at Criticare was not very helpful at all. Thanks!Reply |
1Reply7 years ago | Criticare 8100e Does anyone have the service software for this monitor? It is no longer available from Criticare.Reply |
[list] [*] Easy-to-read 10.4" active TFT color display - view up to 6 waveforms simultaneously. [*] Easy to learn, easy to use menus, dedicated function keys, and simplified controls. [*] Lightweight design and versatile mounting options - adapts readily to department and transport requirements. [/list]
Height | 11 in |
Length | 10.3 in |
Weight | 14 lbs |
Printer | Thermal line printer |
Respiration Rate Range | 6 to 150 |
Temperature Range | 68 to 113 °F |
Width | 13 in |
ECG: Connectors: 3- or 5-lead Leads: User-selectable; I, II, III, aVR, aVL, aVF, V (5-lead); I, II, or III (3-lead) Gain Selection: x1/2, x1, x2, and x4 Electrosurgery Protection: Yes Defibrillator Protection: Yes Pacer Detection/Rejection: Yes Non-Invasive Blood Pressure: Technique: Oscillometric measure upon inflation Automatic Measurement Cycles: 2, 3, 5, 10, 15, 30 min; 1, 2, 4 hr Measurement Range: Adult: 30 to 300mmHg; Neonate: 0 to 150 mmHg Resolution: 1mmHg Transducer Accuracy: ±2mmHg or ±2%, which ever is greater STAT mode: 5 min of consecutive readings Pulse Oximetry: Range: 1% to 99% Resolution: 1% Accuracy: 70% to 99% range: ±2% 50% to 69% range: ±3% <50%: unspecified Method: Dual wavelength LED Heart (Pulse) Rate: Source: ECG (primary); Pleth; NIBP Range: 20 to 300 bpm (30-240 bpm, NIBP) Accuracy: ±1bpm or ±1% (ECG); ±2 bpm or ±2% (NIBP) Temperature: Channels: 1 Range, Accuracy: 68° to 113° F (20° to 45° C): ±0.1° C Probe: YSI-400 and YSI-700 series Respiration : Rate: 6 to 150 breaths/min Resolution: 1 breath/min Accuracy: ±1% or ±1 breath/min, whichever is greater Source: ECG-TTI Alarms : Indication: Audible; visual Silence: Yes; 2 min or permanent Trend Memory: Memory: 24 hr at 30 sec intervals Display: Tabular, Graphical Display: Screen: 10.4" active color TFT Resolution: 640 x 480 pixels Waveforms: 6, maximum Languages: English, French, German, Italian, Portuguese, Spanish, Russian, Chinese Controls : Keys: 9; membrane-activated Rotary Knob: Push and rotate; 24 steps/turn System Outputs: Com Ports: RS 232-compatible; DB9 (Com 1) Nurse Call: Contact switch; 3.5mm stereo phone jack, standard 14mm length Defib/Sync: BNC connector Video Port: High density D-sub 15-pin Printer : Type: Thermal line printer Paper Speed: 12.5, 25, 50 mm/sec Mechanical : Weight: 14 lb; 6.4kg Size: Base unit: 11" (H) x 13" (W) x 10.3" (D); 28cm (H) x 33cm (W) x 26.2cm (D) Power Requirements : Voltage: 100, 120, 220, 240 VAC; 50/60 Hz Consumption: 35 W, typical Batteries: 1; sealed lead acid; life: 3 hr, typical; recharge time: 4.5 hr Environmental: Operating Temperature: 59° to 95° F; 15° to 35° C Storage Temperature: 23° to 122° F; -5° to 50° C Operating Humidity: 15% to 90%, noncondensing Classification: Medical Device: Class II Equipment (IIb EU) Electrical Protection: Class I Equipment Degree of Protection: Type CF, Defib-proof Protection Against Ingress: IPX1
