Meriam - M204 Series
by Meriam
Meriam’s M204 Smart Manometer brings high precision and value to handheld, digital manometer users.
The M204 Digital Pressure Gauge delivers NIST-traceable accuracy of ±0.05% (±0.025% optional) of full scale—independent of temperature effects—making it one of the most precise and reliable pressure measurement instrumentsavailable. With pressure ranges from 10” HO FS to 3000 psig FS, the M204 offers exceptional flexibility for use in biomedical engineering, medical device calibration, and industrial testing.
The M204 pressure sensors measure gauge, differential, absolute, or vacuum pressure, and its easy-to-read display supports eleven pressure units or custom linear scaling for user-defined measurements. Differential models include a square root flow function to display flow rate in user-defined units—ideal for applications involving ventilators, anesthesia systems, and medical gas flow testing. (Generated by AI)
  • Adjustable damping to stabilize pulsating pressure readings
  • Min/Max capture for recording pressure extremes
  • Hold function to freeze readings at any point
  • Auto Record capability for storing up to 240 readings for later review
(Generated by AI)
