STERIS - AMSCO 3043
by STERIS
Gravity/Pre-vacuum Single Door Sterilizer.
Designed for sterilization of liquids in flasks with vented closures, at 250 degrees f, and also heat-and-moisture-stabile goods at 270 degrees f.  Pre-vacuum designed for efficient, high-volume processing of heat-and-moisture-stabile materials, such as fabrics, wrapped hard goods, glassware at 270 degrees f
-Joenrg
7 years ago
Printer
printer is printing garbled . I have replaced the printer and immediately upon replacing it printed beautifully however not even half way through the day it reverted back to just printing lines no data. can you give me a suggestion on how to resolve this? Reply
  • Control column includes an easy-to-read vacuum florescent display
  •  An integral thermal printer
  • Pre-vacuum unit will also run gravity-type-cycles
