TOP Corporation - TOP 3300
by TOP Corporation
Infusion Pump
LED status indicators at the top unit allow the pump operating status to be checked even from the back of the unit or at a distance. The panel face is inclined upward, enabling the display to be checked and keys on the panel worked without having to bend over.
1Reply3 years ago | Volume rate change for maximam How to adgest maximam rate Reply |
1Reply4 years ago | Need service manual Kindly can you provide me with the service manual, i have 10 infusion pumps, model 2007.Reply |
2Replies6 years ago | Infusion Pump Need Service Manual for trouble shootingReply |
[list] [*] Lighted status indicators [*] Inclined panel for easy visual confirmatioon [*] Broad range of delivery rate settings [*] Conveneient Battery indicator [*] Battery Replacment is easy [*] Improved Drop sensor [*] Occulison alarm-triggering pressure in adjustable [*] Memory function [*] Clears EMC standards [*] Automatic Shutoff [*] Alaram Repeat [*] Data memorize function [*] Sound setting [*] Power source switch alarm [/list]
