Bovie - Centurion
Standard dual and single CS-DCFORUMSView All
- CLEAR - The Centurion Standard uses a 15″ diameter allowing homogenous light distribution and optimal shadow reduction Centurion Standard Surgical Lighting
- BRIGHT - The Centurion Standard is output rated 43,500 lux (4000 foot candles) at 4,000 Kelvin color temperature
- VERSATILE - Additional lighting accessories are available to construct the perfect lighting system solution
- EFFICIENT - 2000 hour, 90 watt bulb is effortlessly replaced when needed
- SMOOTH - Light-head smoothly adjusts into perfect placement for ideal visualization during procedure
