Soering - ARCO-1000
by Soering
ARCO 1000 [list] [*] Argongas for contactless control of hemostasis. [*] Very efficient in General Surgery, Endoscopy, Gastroenterology, Laparoscopy. [*] The compact unit with automatically output restriction. [*] Defined limited gasflow to 0,1 and 2,5 ltr/min. [*] Requires no link to other Electro-Surgery units [/list]
0Replies4 months ago | manual tecnico procuro software e manual tecnico para dar solução a dois equipamentos parados. Equipment: arco em C movel Translation: I am looking for a technical manual to solve two pieces of equipment that are out of order.Equipment: mobile C-arm Reply |
Applications: [list] [*] Neurosurgery [*] Endoscopy [*] Laparoscopy [*] Surgery [*] Gynaecology [*] Urology [/list]
| Height | 150 mm |
| Length | 560 mm |
| Weight | 21 kg |
| Width | 430 mm |
Mains voltage switchable to 230V ± 10% 50Hz ± 5% 115V ± 10% 60Hz ± 5% Power draw 4 Asb (230 V); 8 Asb (115 V); 10 Asb (100 V) Power consumption 1000 VA Classification (acc. MDD) 2b Safety class (acc. EN 60601-1) I Recommended gas Argon 99,99 % Applied standards EN 60 601-1; EN 60 601-2-2;
