Sinothinker - SK3002B1
Sinothinker's SK3002B1 Semi-auto chemistry analyzer.FORUMSView All (3)
0Repliesa year ago | Sinothinker - SK3002B1 Dear All, Pls help to find the Sinothinker - SK3002B1 opration manual. |
0Repliesa year ago | Sinothinker - SK3002B1 Dear All, Anyone can send Sinothinker - SK3002B1 operation manual pls. Reply |
0Replies2 years ago | Creatinine Measurement Errors After Zero Setting, and measuring the standard and hence trying to measure that of the test, the system generated factor display changes to "error" and then failure to analyze the Test hence no results display. What must be done to resolve this issue? Reply |
[list] [*] 7 inch Color LCD,Touch screen [*] 10 incubator,3 timer [*] Flow cell and Cuvette test mode compatible [*] Real time curve showing [*] 7 wavelength ,80 test item pre-programmed [*] Memory for 10,000 sample results [*] Light source hibernate function making lamp life longer [*] RS232 interface, PC connecting [/list]
Height | 160 mm |
Wavelength Range | 340 to 630 nm |
Length | 340 mm |
Weight | 5 kg |
Sample Volume | 0 to 3000 µL |
Width | 270 mm |
