Philips - BiPAP S/T
by Philips
Ventilator
Aligned with the same platform as the [url=https://www.medwrench.com/equipment/3011/philips-pr-system-one-cpap]System One[/url] sleep therapy technology, the Philips Respironics BiPAP S/T Non-Invasive ventilator offers a straightforward user interface and integrated heated humidification for easy setup and management.
  • Two trigger mechanisms
  • Bi-level S and S/T triggers respond on demand or automatically to deliver prescribed therapy
  • Digital Auto-Trak - enables optimum patient/ventilator synchrony, recognizes and compensates for leaks, and automatically adjusts variable trigger and cycle thresholds
  • By-Flex pressure relief technology - makes BiPAP therapy more like natural breathing by delivering pressure relief
  • Heated tube - has a temperature sensor at the end of the heated tube to deliver the selected level of humidity to the patient while providing protection against rainout
  • DirectView management and reporting - gathers, stores, and analyzes data and streamlines reporting to help identify adjustments needed for effective treatment and patient care
Height10 cm
Length 18 cm
Weight1.63 kg (without humidifier)
Width14 cm
  • Breath Rate: 0 - 30 beats per minute
  • Data Storage Capacity:up to 3 mon
  • Electrical Requirements:100-240 VAC (50/60 Hz)
