Philips - BiPAP AVAPS
Ventilator
Aligned with the same platform as the sleep therapy technology, the Philips Respironics BiPAP AVAPS Non-Invasive ventilator provides the comfort of pressure ventilation and the consistent efficacy of assured tidal volume.
- Automatically adapts to your patient's changing needs - maintains optimal patient comfort while supporting patient care and treatment efficacy.
- Digital Auto-Trak - enables optimum patient/ventilator synchrony, recognizes and compensates for leaks, and automatically adjusts variable trigger and cycle thresholds.
- Bi-Flex pressure relief technology - makes BiPAP therapy more like natural breathing by delivering pressure relief.
- Heated tube - has a temperature sensor at the end of the heated tube to deliver the selected level of humidity to the patient, while providing protection against rainout
- DirectView management and reporting software - streamlines reporting to help identify adjustments needed for effective treatment and patient care.
Height | 10 cm |
Length | 18 cm |
Weight | 1.36 kg (without humidifier) |
Width | 14 cm |
- Breath Rate: 0 - 30 beats per minute
- Data Storage: up to 3 mon
- Electrical Requirements: 100-240 VAC (50/60 Hz)
