GE HealthCare - Uroview FD
by GE HealthCare
The Uroview FD provides precision imaging, dynamic workflow and optimal access to help meet your clinical needs.
0RepliesSat Jul 23 2022 | uroview FD 8k I am looking for service documentation fo this system. it is not available on the GE document library mainly user manuals are there. Thank you llpbio2@gmail.com Reply |
[list] [*] Precision Imaging – View your images in superb detail on the Uroview FD’s large, high-resoultion monitors that use digital flat detector imaging technology. [*] Dynamic Workflow – From patient set-up to case cleanup, you have control with Uroview FD simplifying and maximizing the dynamic aspects of your workflow. [*] Optimal Access – From transferring a single patient to a full day’s caseload, the advanced ergonomics and table positioning of the Uroview FD give you the best access to the patient and promote a comfortable environment for you and your staff. [*] Optimize dose management - The Uroview FD is designed to provide diagnostic image quality using advanced dose saving strategies, including larger field of view for fewer exposures. [*] Quick cleanup - clean up easier with a hinged, carbon fiber patient table top, fewer cables to work around, and an optimized mechanical design. [/list]
Trendelenburg: -20 to 88 degrees
